Как запрограммировать родной брелок к автомобилю ?!Программирование брелка.Цитата
Honda Element 03-04 Keyless Remote Programmi ng Instructi ons :bu:
Please follow the instructi ons step-by-step in order for the remote programmi ng to work. These instructi ons are useful for 2003 2004 Honda Element. This procedure clears the transmitt er codes and creates new ones, so you must program all remotes at the same time, even if one or more is already working.Enter the car and close all doors.
Each of the following steps must be completed within five seconds of completin g the previous step. If you take longer or make a mistake, start the entire procedure over again.
Insert the key into the ignition, and hold one remote in your left hand. Whenever the instructi ons say to press the LOCK button, you should press the lock button on the remote for about a second and then release it.Perform each of the following three steps in order, then repeat all three steps two more times, for a total of three times each:
1. Turn the ignition switch to the ON position, marked II.
2. Press the LOCK button.
3. Turn the ignition switch to the Off position, marked I.
Do this three times!
Next, turn the ignition switch to the ON position (II) for a fourth time.
Press the LOCK button again. The door locks should now make a cycling sound, indicatin g that the system has entered Programmi ng Mode.
Press the LOCK button one more time to program this remote. If you have other remotes to program, press the LOCK button on each one in turn. The door locks should make the cycling sound after you press LOCK on each remote. You may program up to three remotes, and they must all be programme d within ten seconds of each other.Turn the ignition off and remove the key. The remotes are now programme d and may be tested.
If you’ve got a trunk/hatch release, hold the button for this function for a few seconds.
Перевод переводчиком
Хонда Элемента 03-04 Keyless Remote Programmi ng Instructi ons :bu:
Пожалуйста последуйте за instructi ons постепенно для того, чтобы дистанционный programmi ng, чтобы работать. Эти instructi ons полезные для 2003 2004 Хонда Element. Эта процедура очищает transmitt er кодирует и создает новый те, так что Вы должны запрограммировать все дистанционные в то же самое время, даже если бы одно или более уже работает.
Введите автомобиль и закрывайте все дверей.
Каждое следующее шагов должно быть завершено в течение пяти секунд completin g предшествующий шаг. Если Вы берете дольше или делаете ошибкой, запустите целую процедуру над снова.
Включите ключ в зажигание и держите один дистанционный в вашей левой руке. Всякий раз, когда instructi ons говорит, чтобы нажимать кнопку ЗАМКА, Вы должны нажимать кнопку замка на дистанционный приблизительно по секунды затем выпускать это.
Выполните каждые следующие три порядка входить затем повторяйте все три шага два более время, для итога три раз (а) каждого:
Станьте ключом зажигания на ON позицию, выделившим II.
Нажмите кнопку ЗАМКА.
Станьте ключом зажигания на позицию, выделившим I.
Сделайте это три раз (а)!
Затем, станьте ключом зажигания на ON позицию (II) в течение четвертого времени.
Нажмите кнопку ЗАМКА снова. Замки двери должны теперь сделать циклической работой звучать, indicatin g, что система ввела ng Способ Programmi.
Нажмите кнопку ЗАМКА еще одно время, чтобы программировать этот дистанционный. Если Вы имеете другие дистанционные, чтобы программироваться, нажмите кнопку ЗАМКА на каждый в свою очередь. Замки двери должны сделать циклической работой звучать после того, как Вы нажмете ЗАМОК на каждый дистанционный. Вы можете запрограммировать вплоть до трех дистанционных, и они должны все будут программа d в течение десяти секунд друг друга.
Станьте зажиганием и удаляйте ключ. Дистанционные — теперь программа d и может быть протестирована.
Если у вас есть шина/люк выпуска, подержите кнопку для этой функции в течение нескольких секунд.
нужно проделать 3-и раза одну процедуру (двери должны быть закрыты, а замки открыты):
выключить зажигание
включить зажигание
нажать на брелке «Замочек»
выключить зажигание
на 4-й раз
включить зажигание
нажать на брелке «замочек» при этом центральный замок немного отщелкнет
повторно нажать на брелке «замочек», а если 2-а брелка, то на втором тоже нажать на «замочек» (если не нажать на втором, то второй уже не будет работать)
ВСЕ — брелки запрограммированы!!!
Вот еще о том же, от Карельскоого Хондавода на «Элементе».
Не нашел ссылку, поэтому выкладываю здесь: Программирование брелка (взято с форума Элемент-клуба)
- 1. Возьмите в руки все брелки, которые у вас есть — и старые и новые.
- 2. Основную процедуру программирования вы будете осуществлять, используя один брелок, а в конце — на этапе инициализации, необходимо будет нажать кнопку «замочек» на всех имеющихся у вас в наличии брелков.
- 3. Нужно проделать 3-и раза одну процедуру без промедления (двери должны быть закрыты, а замки открыты):
- 3.1. выключить зажигание
- 3.2. включить зажигание
- 3.3. нажать на брелке «Замочек»
- 3.4. выключить зажигание
- 4. Не делая паузы после мероприятий по п.3
- 4.1. включите зажигание
- 4.2. нажмите на брелке «замочек» при этом центральный замок немного отщелкнет
- 4.3. повторно нажмите на брелке «замочек», а затем на 2-м брелке (затем на 3-м ….) тоже нажмите на «замочек»
- 5. Процедура программирования завершена — брелки запрограммированы!!!
